We used to have hot water, but the last couple of trips, we did not. My husband has been trying to figure it out, but so far, still a problem. Ideas for us to try?
Without your year and model, our suggestions might not be on target. If you have a pre-Nautilus trailer, the solution may be as simple as putting the valves in the proper position. Or, you might have a failed or not adjusted properly "mixing valve".
2024 Kia EV9
