Hey y'all, I have a 2023 320s "signature series", which has a dry weight of 1946. It's been sitting since Memorial Day and I'm getting ready for a fall trip. The tires are Goodyear 235/75r15. The max psi is 51. This is my first camper. If this were a car I'd get pretty close to the max but do you do that with a camper?
I'll fill it with water (13 gallons I think) and have a few odds and ends in there, like a duffel and a couple of camp chairs.
I'm planning to pick up a tire inflator/air compressor so I can fill the tires at home.
Any tips on the PSI or filling the tires generally?
Thank you fellow campers!
0 ·
John, Northern California
Is ST a brand or a designation for trailer tire? I didn't see it on there but I wasn't looking. Will check in the AM, thanks.
Based on the table above I run at 45 psi which is still good for almost 500 lbs more than the T@b is allowed to weigh.
I generally make a habit or keeping the tanks empty when I tow. To each their own, but water is heavy, moves around, and I have never had a problem filling up en-route.
I will keep looking for a Goodyear-specific source.
I found a 2022 tire care guide for LT235/75r15 and it would have it at a psi between 50 and 55 with dry weight. The max is 51 so that sounds a little dicey if I have water.
It's very frustrating that it's so hard to to figure everything out for this camper. Thank God for this forum though.
Proper Tire Inflation
Correct tire inflation is a key component in tire care. The recommended maximum inflation pressures for your tires are indicated on the certification label or in your owner's manual. Since RVs can be loaded with many different configurations, the load on each tire will vary. For this reason, actual air pressure required should be determined based on the load on each individual tire. Inflation pressure should be adjusted to handle the tire carrying the heaviest load, and all tires on the axle should be adjusted to this standard.
I figure my 2017 320 comes in around 2000-2100 pounds or so. I have my Endurance set at 50PSI.
This is the Goodyear RV tire explainer page.
https://www.goodyearrvtires.com/tire-inflation-loading.aspx
Thanks for the link. I had read that and it brings me back getting the dealer's table on psi by weight. Unfortunately, I can't find a Goodyear psi table that shows my tires. That's why I made the original post, as I found other threads about how these tires were standard when my camper was built. Hoping to find someone who had these tires and found the psi/weight table. Or had these tires and could tell me what psi they use based on their model and then I'll just make a guess based on their weight.
I did find other stuff from Goodyear that said "consult your vin placard", which doesn't work for me since the tires don't match the placard.
I emailed Nucamp, no response yet. If I haven't heard by tomorrow I'll start trying to track down someone at Goodyear. Or maybe call the dealer but they don't seem to be much on details.
