Oyster 3 GPS tracker by Lone Star - anyone using it?
Have been comparing cost of ownership of a few trackers and this one wins. Just curious if any of you folks are using it and if so, what you think of it.
  • MarcelineMarceline Member Posts: 1,745
    edited September 2025
    "We have created partnerships with cellular carriers across the globe to make sure your tracker works when and where you need it to."
    There's nothing inherently wrong with this variety of tracker, but it's important to recognize that it won't send a fix if it can't connect to a cell tower. Something like a Spot Trace (what I use) is more expensive because it transmits fixes via satellite, not cell service.
  • SLJSLJ Member Posts: 640
    You would have to be way out of cell range to have this not work. I've used it for four years and I have never had it not work through the Smokies, Adirondacks, Midwest, and New England, even when I have zero cell service on my phone. GPS location is spot on. If it's stationary for more than five minutes I get a text alert when it starts to move if my phone has cell service. If not I get the alert when I have service again.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
    This device will get fixes (location data) from satellites even when there is no cell service. It will constantly store that GPS data. But it will not transmit that data to the owner of the device until it returns to an area where there's cellphone service. In the West, especially in mountainous areas--but also in other sparsely populated areas--there are some pretty big holes where there is absolutely no cell coverage for the tracker to connect to. I'm not saying that no one should buy it, I'm just saying that a potential buyer should be aware of this limitation. Theoretically, if someone stole your trailer and took it to a place where there's no cell service you wouldn't be able to track it. If your family was worried that they hadn't heard from you in a while they wouldn't be able to track you down if there was no cell service for the tracker to connect with.
    From their website
    Your tracking device will have coverage almost everywhere in North America, unless otherwise specified.  Our trackers require a 4G/5G Cat M1 cellular signal in order to operate.  Your tracker comes with a built-in SIM and the device is working out-of-the-box within 5 minutes. No need for a local SIM card and you cannot change the SIM. It will work anywhere in North America that has a 4G/5G Cat-M1 cellular signal.
  • HardFaultHardFault Member Posts: 20
    Thanks for your inputs @Marceline & @SLJ . Appolgies for my slow reply. Life got in the way a little.
    @Marceline Thanks for pointing out that drawback of a cellular-based solution. I'm aware of that issue but I made a budget decision not to go with a satellite based solution. If it gets removed to a location not visible to cellular, we'll fall back to theft insurance.
    @SLJ thanks for your sharing your experience with this. I chose this unit, have had it active for about 10 days and am happy with it so far.
  • mx4789mx4789 Member Posts: 47
    I used a tracker by LandSeaAir (or something like that). The device itself was ~$30 the service depended on update intervals. I chose the plan that was around $20 a month. The device could be wired into the battery or use its own internal battery. It would go dormant until it sensed motion and then it would wake up and start transmitting. The internal battery would last for many months while dormant (ie, trailer just sitting in the yard). I finally discontinued the service after a year or two when my camper got old enough that I decided if someone stole it that I really wouldn’t want it back. I’ve seen several videos of local trailers getting stolen and the thieves are not gentle (driving off over curbs/chocks and with a wheel boot still attached). Just my 2cents worth, but if you have adequate insurance coverage you may not want your camper back.
    2025 Tab 320 S BD
    2024 Nissan Frontier
