Water staining area around outside wall Nautilus control panel inside access to pump
I have noticed water staining in area around outside wall on and around Nautilus control panel inside access to pump and Alde system  Has anybody had this problem and where was the water coming from.  No evidence of water leaking from fittings inside camper.  Could be water from hose connection and use of black water flush?  Connection tested water stained areas with moisture meter very wet.
  • TimandLaurie
    TimandLaurie Member Posts: 34
    The dampness is below black pipe in picture inside camper below the head of bed.
  • elbolillo
    elbolillo Member Posts: 575
    Water is more than likely leaking in from the Nautilus compartment floor. This happened to me. I had to generously caulk around all the seams of the compartment to stop the leaking. The Nautilus compartment is very poorly designed. It should have been a one-piece seamless pan.
  • Binghi
    Binghi Member Posts: 417
    Keep an eye out for drips when you use the city water and black water inlets.
  • manyman297
    manyman297 Member Posts: 1,439
    Our black tank flush connection got the nautilus tends to loosen over time. Every season I tighten the water connections to the nautilus.
    2021 400 BD
    2020 Tacoma TRD Off-Road
