Check receptacle on Alde. This picture is the receptacle to the Alde Boiler. When using electric to heat the Alde, noticed overheating at neutral connection. removed receptacle and replaced with one where the wires are stripped to connect, making a better connection.
https://tab-rv.vanillacommunity.com/discussion/comment/182995/#Comment_182995
Camper: nuCamp T@B 320S BBC 480W solar and 200ah LiFePO4
TV: JLUR | Tow Package | 100ah LiFePO4 | 200W Solar | DCtoDC
https://revkit.com/donmontalvo/ | https://donmontalvo.com
Nucamp did not see fit to provide GFI protection on the separate, dedicated 120v circuits to the Alde and Air8.
With the plumbing at floor level I fully expect to see water on the floor at some point, hence I replaced the OEM pressfit fire hazards with GFI duplex outlets.
Travel trailer manufacturers' compliance with NEC/NFPA70 is optional, so what we get can be haphazard... or just hazard. A press-fit copper connection in a bouncing trailer is completely unsuitable.
