2026 tab360 television
Took new tab out first time last weekend and loved it. Tried to use the television and couldn’t get it to work. There are no instructions in the owners manual or in the packet we got.
Turns on and that’s it. No internet so couldn’t use any apps - couldn’t stream fr phone -no tv stations. Presume it should pull away from wall couldn’t find any release to do that.
Any suggestions- ideas or words of wisdom.
Radio and speakers are amazing so there’s that.
  • Yoshi_TABYoshi_TAB Member Posts: 566
    edited October 2025
    Hi,
     If you scroll over to the settings section, (left side on the home screen, press the home button on the remote), you can scroll to network.  Then you can use your phone as a hot spot and connect to the internet or in some cases to the campground wifi (if available).  Then you can use any of the apps (Netflix. Prime, ESPN,  etc) as the TV is  a "smart TV" with a bunch of apps.  I'm be happy to take  some screen shots if that would be helpful.
    If you have an external antenna, you can hook it up to the coax connector in the Nautalis and scan for local over the air channels if in range.
    2025 360 CS
    Southern Maryland
  • CaboosCaboos Member Posts: 11
    The network screen didn’t have an option for hot spot- only google options
    no wifi around
    Seems there is an external antenna but never for any info on it just noticed the other day when packing up
    not set up like any device or smart tv we have had
    thanks for info
    edited October 2025
    Hi,
    Because I did not have it in front of me, my response was not accurate:
    Go to Home Screen > Settings> Network> Network Configuration  then it lists all the hotspots or wifi connections available.
    (I snapped more than one picture..but it's only letting me upload 1)
    2025 360 CS
    Southern Maryland
  • MarcelineMarceline Member Posts: 1,743
    All of the Jensen manuals are available here.
    https://support.asaelectronics.com/product-tag/jensen/
    If you put the model number of your TV in the search box the manual should come up.
