Tab 360 Hot Water Tank
New Member and Tab 360 owner. It will be getting down to 35 degrees two evenings. Do I need to empty the tank, the unit is storage until I take on a trip next week.? Any advice is greatly appreciated.
"35" is not freezing. The trailer will be fine...as long as that forecast you are reading holds true. The only real answer for your trailer, or any trailer, is you must know when and why and how to winterize the plumbing. Winterizing is always better than worrying, and the "blow out" method of winterizing will allow you to drain the trailer, blow out the plumbing with a compressor, use a minimal amount of antifreeze, and let you de-winterize quickly when the weather improves.Do you have the Nautilus Manual? Have a look at it, and you can see how simple most of this is to do.There are plenty of threads on what compressors to use and the basic process.
Towed by 2014 Touareg TDi1 -
Thanks @pthomas745. I appreciate your advice. I do not have a Nautilus manual. Can I download it from somewhere? I have watched plenty of videos from NuCamp. It does seem pretty simple.0
Here is the manual. Take pictures and show us the workings of your trailer if you can, we would love to know more about how these setups work. And, please ask questions, anything you can think of. The process gets a bit bewildering the first time you stand there trying to sort it out! We have tons of threads about winterizing and the Nautilus.
this is great @pthomas745. saved to my desk top. do happen to know the keder rail size. some say 8.5 or 8.0
thanks0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
