15 amp fuse in 2018 320 cs-s below bench in control center for overhead lights keeps popping
LawyerboyLawyerboy Member Posts: 127
Happy Thanksgiving to you and yours everyone.  So, noticed no overhead lights or porch light.  Went into the converter center and noticed a red light on to the right of the 15 amp flat blade fuse.  Bought replacements, and each time I install and send power to the trailer, that one pops again.  I have the above fan running.  The radio is lit up.  I have a dehumidifier plugged into the gfi outlet left of the converter. Any thoughts would be appreciated.  TY so much.  Mark
  • MuttonChopsMuttonChops Member Posts: 1,911
    While I don't have direct knowledge of the 2018 CS-S wiring . . . in general nüCamp connects all the 12VDC lights to the same fuse or two fuses.
    For the12VDC lights that are not turning on . . . the most likely issue is a bad connection at one of the light fixtures.  One of them is shorting the +12VDC to the return/ground wire; it could be in the fixture (bulb area), switch, or the wire connections.
    Again that's the most likely source, investigate and let use know what you find.
  • LawyerboyLawyerboy Member Posts: 127
    Thank you.  Ironically I replaced the galley overhead light. The wire was short.  Wonder if it came loose. Will advise.
