I would like to buy an infrared thermometer to check temperature of the brake drums when on the road. Prices range from $5.99 (Menard’s Black Friday sale) to >$155 (some Milwaukee industrial version).
What should I look for in a thermometer? I see a “distance to spot” ratio; what does this mean? Is it important?
Any recommendations or suggestions?
Southern Maryland
Trips - 48 Mileage - 63,452
so what temperature is too hot for brakes or bearings ? How do you distinguish between brake temp or bearings with this gizmo ?
You really don’t need one of these gizmos - it will just keep you awake at night.
St Catharines, ON
2017 Dodge Durango AWD with Tow Package IV
A can of Skyline Chili in the pantry
I knew nothing about the T@B brakes on my 400 and just got a brake adjuster tool and followed the instructions. They are not very complicated so if a simple adjustment doesn’t help, you need a better trailer shop to tear down the hub/ brake assembly
https://tab-rv.vanillacommunity.com/discussion/comment/170594#Comment_170594
