I can’t seem to quickly find an answer, or make any search engine understand what I’m am asking.
I have a 2025 320 S Boondock. My cassette toilet has a separate fill (fresh water) tank. There is a water level indicator (and fill tube) inside the cassette compartment. Does anyone know how much water the fresh water fill tank (aka the flush tank) holds? What happens if you over fill it? Where does the excess water go?
When I add water, the level indicator (a clear tube filled with water) rises but after a few seconds it settles back down to about half way.
The owner’s manual says that there isn’t a fill tank, which is either wrong or is referencing another version (which is weird since it is for my camper year/model).
Anyway, just curious and somewhat frustrated since everything thinks I’m asking about the black tank portion of the cassette, or glosses over the specs if it does mention the fill tank. TIA!
2025 Tab 320 S BD
2024 Nissan Frontier
0 ·
No reason to think nüCamp has changed the above for later model years.
As for the door, your are correct. The hinge normally goes in the front. I'm betting the installed it this way so closing the door may push the fill tube in. If the door was the other way and the fill tube not fully stowed, it would jam.
Parting thought: The trailer owners manual has to meet DOT requirements for certain subjects. For information of any component of an RV, consult the manufacturer of the component.
"Just Enough"
