Installed a mount for a second computer monitor/display in the dining area of a T@B 400
jimcenname
Member Posts: 348
As a full-timer in a T@B 400 I miss a second monitor/display when using my computer. Just not enough room. I solved that recently when working on another project. I added an articulating monitor support arm and a 14" touchscreen display to my dining area. Instead of using the clamp method as provided by the monitor-arm vendor I screwed the mount directly to the wood that encases wiring, AC duct and Alde convector at the base of the bench seat. Note, I installed the Lagun arm and table several years ago and that enables this mod. Since I am solo the arm's location doesn't affect my use of the dining area.
2019 T@B400
Southern California
Full-timer since 2019
Southern California
4
How stable is the table? Do you find it "bouncy" when typing/working? I've been thinking about taking a "working vacation" and I was actually contemplating using the television (I have a 320 BD) as a second monitor.2025 Tab 320 S BD2024 Nissan Frontier0
I'm pleasantly surprised the table is pretty solid. BTW when towing I remove the monitor via quick disconnect, place it face down on the bed2019 T@B400
Southern California
Full-timer since 20190
