TAB 400 Alde Glycol Routing = questions =
MuttonChops
MuttonChops Member Posts: 2,027
Background
I'm considering replacing a '18 320S with a '25+ 400 and am trying to get educated on the trailer differences.
Issue:
The TAB 400 has a larger glycol 'heater' loop.
Air Force Guy factory tour videos are dated and don't cover everything plumbing/electrical/Alde 'behind the walls'.
Request:
For those of you that have dug into the TAB 400 Alde 'heat', please review/edit/comment on this draft diagram that outlines the TAB 400 Alde Glycol Loop.
TIA
 & used a new-to-me drawing tool so forgive the overall quality
02-11-26  Diagram Removed, updated version posted later in thread
  • dsfdogs
    dsfdogs Member Posts: 640
    In the bathroom, there is an element under the floor plus the one on the wall below the shower handle. I don't know direction of flow, but I could always feel the heat in the bathroom first, also in the cubby on driver side near expansion tank. The others were much more elusive.
    Debbie in Oregon
    Sold 2023 Tab 400
    Sold 2018 T@B 320S
    qhumberd Administrator, Moderator Posts: 863
    @MuttonChops Other than the location of the expansion tank, which is in the closet in my 2019 400, the diagram is correct from what I have inspected. In the bathroom proper below the water controls is an arched metal pipe that heats that area, and then it exits to the expansion tank and from there to the boiler. Under the bathroom floor in mine is a typical aluminum convector. I have one bleed point at the arch in the bathroom. I know that newer models added bleed valves at other locations. Your flow is correct for my unit.
    pthomas745 Administrator, Moderator Posts: 4,627
    This is a thread from a couple of years ago with pictures and descriptions.
    pthomas745 said:
    . . . thread from a couple of years ago with pictures and descriptions.
    Thanks.
    I searched with several keywords and never found it  :|
  • manyman297
    manyman297 Member Posts: 1,436
    Don’t forget about the manual bleeds on the rear/bed convector, the kitchen convector and the passenger dinette.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    edited February 12
    Thanks to everyone for the comments/clarification.
    The link @pthomas745 proved to @bergger 's detailed reference pictures was very helpful.
    I've got what I need for now - - - will update/customize if/when a 400 is purchased.
    For your entertainment:
  • B0atguy
    B0atguy Member Posts: 267
    edited February 2
    There are 6 convectors in a 400 . You missed the one that is adjacent to the cool cat area in your final drawing - Left side , front of the 400 - dinette seat area . The heat from that one goes up into the window cavity .
    This thread shows pictures of each convector quite well .
    https://tab-rv.vanillacommunity.com/discussion/18266/t-b-400-convector-locations
    edited February 12
    Minor update . . @BOatguy . . caught one missing on driver side
  • manyman297
    I believe you’re still forgetting the bleed valve on the passenger dinette convector.
    2021 400 BD
  • Horigan
    Horigan Member Posts: 893
    My 2019 400 has two hoses going to the expansion tank, inlet and outlet. Did that change to a single hose on later models?
    Rich
    2019 T@b 400
    Bellingham WA
    Most posts comment or show Two Hoses to the expansion.
    Another item missed in my Draft Diagrams
    From @bergger post on locations, pictures
    Here is my current diagram version
    for your reference and entertainment
    Time to work on something else
    Attached PDF file has the above diagram and a few basic 3D images
