Hi all. First time user here.
My wife says that there are numerous online accounts of a "smart" alternator's output being used via pin 7 of the trailer connector to directly charge the camper's two paralleled lithium batteries with no issues, despite the fact that the tow vehicle's battery (in this case a 2023 Maverick) is of the lead-acid type.
Would this mean that the alternator's built-in voltage and current regulation is biased for whichever battery type wouldn't be harmed by the other one's charging voltage/current being used? Or does the pin 7 connection originate from a separate smart regulator circuit, independent of the one that charges the truck battery?
Otherwise, could these stories simply mean that the users are getting away with a risky setup, and there really should be an Li charging adapter (the so-called DC-DC converter?) between the truck's 12V+ supply and the trailer?
Thanks for any and all input.
-e
DC-DC converters do solve the charging issue but also drastically increase the current draw from the tow vehicle which typically blows the trailer power fuse. That's why people end up installing dedicated trailer charging wiring in the tow vehicle.
I suspect horror stories about burning up alternators are from folks running heavy gage wires directly from an older "non-smart" alternator attached directly to a larger lithium battery setup.
My 2016 Honda Pilot would barely offset the draw from my 12v fridge when towing with the original lead acid deep cycle battery via the 7 pin plug. I installed a lithium iron phosphate battery along with a 30 amp DC-DC charger. It is connected to the TV battery via a 4 AWG cable, then connected to the trailer via an Anderson plug. I discovered quickly that the DC-DC charger back fed current to the TV and I ended up pulling the 7 pin power fuse. The Honda alternator's voltage throttles back and was so irregular that turning on the headlights was the only way to keep the Victron software on and charging the battery. I picked up a digital voltage reading USB phone charger and it frequently goes below 12.6 volts without the headlights on.
The 30 amp Victron smart charger draws up to 45 amps and I have a 60 amp circuit breaker near the battery. It all works well and typically get 26-28 amps going down the road when the battery is depleted.
I wasn't thinking in those terms on account of having dealt mostly with the kind of current you encounter in electronics, which is generally negligible except in audio output circuits. So I never consider that the resistance in 15' of light-gauge power supply wire has has no meaningful effect in matters of mA, but gets critical when you remove the "milli" thanks to Mr. Ohm and his damned Law.
Shame on me, and thanks.
