Battleborn safety issue per Will Prowse?
Is anyone out there following Will Prowse on YouTube about Battleborn battery safety issue of overheating?
I have a 2025 360CS black canyon with standard 100aH Battleborn battery and wondering if this has come up for any nucamp owners?? Thanks!
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,484
    It has been discussed in several threads.  I've followed it closely at both his web page and the videos.  It is hard to say how many other owners here are following it "closely".  I know if I had a Battleborn I would be looking very closely at the positive battery terminal to look for discoloration, as described in the videos.
    The problem I have for this issue is the difference in how batteries are charged and discharged in a trailer, compared to the charging and discharging rates someone powering a large solar array for a home, for example.  Do we put that much stress on a battery?  Does having the "large" battery setups with the Multiplus inverters with owners running the AC make a difference?  These are hard questions to answer.
    What is interesting in the various threads is learning how Battleborn has marketing agreements with major manufacturers across the RV industry, including NuCamp.  Which is why the industry heavily promotes the Battleborn brand. Which is fine.  The question will become what happens if Battleborn no longer supports their warranties in the future, or goes bankrupt.
    In any case, a difficult thing to sort through.
    This is one thread:
  • Yoshi_TABYoshi_TAB Member Posts: 564
    Have you seen the video with the 270Ah battery.  Seems like same if not worse.  That battery is used with lithium package.  Make your own decision.
    2025 360 CS
    Southern Maryland
  • qhumberdqhumberd Administrator, Moderator Posts: 756
    I agree with @pthomas745 that most RV users will not stress a 100Ah Battleborn from a charge and discharge perspective like Prowse's testing shows. What is more of a concern is the lack of build quality and vibration resistance (or not) built into this (or any) battery. So inspecting regularly is certainly prudent for any brand of battery.
    My other concern is how Battleborn is dealing with valid warranty concerns, which is to offer to inspect if the owner ships the battery back at the owner's expense and then make a determination. For such an expensive battery this is pretty much no warranty at all.
  • IdgieIdgie Member Posts: 7
    Much appreciation for any and all feedback/thoughts here. I’m a RN not an electrician 😉 The Battleborn response thus far does not appear to be exemplary and once our camper is up and about from winter I will be sure to inspect my battery regularly. Thank All!
  • MOS2MOS2 Member Posts: 33
    So what should be inspected on the battleborn?
    "To address questions that have recently surfaced about terminal heating and fastener design, it is important to highlight that what some observers view as a failure is a safety device working exactly as intended. The aluminum nut used in our 100Ah packs’ positive terminal is a purpose-built thermal failsafe. It is engineered so that the plastic deforms and disconnects when excess heat is present.”
    Might want to check out Will’s video onYouTube as I am absolutely no expert on this!
  • Grumpy_GGrumpy_G Member Posts: 684
    This is one of the most hilarious spin attempts ever. Nothing disconnects inside the battery, the nut and bolt merely lose clamping force when the plastic melts. Which makes the problem worse.
