Can the stabilizers safely support the weight of the T@b for a short time?
vito
vito Member Posts: 181
After unhitching and lowering the jack to the ground (or to a block of wood) and moving my TV away, I decided that I should have put the dolly wheel on before unhitching so that I could move the T@b just a bit. Would it be safe to raise the jack up enough to slide the dolly wheel on, leaving the weight of the T@b to be supported by the four stabilizers?
2016 T@b S Maxx
2011 Subaru Outback
Rockford, Illinois
  • DurangoTaB
    DurangoTaB Member Posts: 754
    On one hand many will tell you not to use the stabilizers as levelers...on the other hand the LG instructions say to lower the tongue, lower the rear stabilizers, then raise the tongue and put all the weight on the rear stabilizers and tongue (if I did this I'd also lower the fronts)... So I think you're OK.
    J.D. & Sue
  • Mouseketab
    Mouseketab Member Posts: 1,238
    I know of a few folks that once they are level and stabilized, they raise their wheel front wheel up. As long as you are also on your tires, you should be OK, but NEVER use the stabilizers to jack up a tire. When I replaced my jockey wheel, I also had my camper on both tires and all four stabilizers. I think you will be fine.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • Sgtjohn
    Sgtjohn Member Posts: 238
    I raise the front of mine, weight on rear stabilizers to remove both wheels for garage entry then lower the T@B after mounting cut down rims..  The manual says it's acceptable so I do it.
  • ELK
    ELK Member Posts: 213
    What would happen if the weight was on the stabilizers? ANd how can they level the trailer without taking weight?
    2015 T@B Max S.  TV: 2015.5 Volvo XC70.
  • Nomad
    Nomad Member Posts: 7,209
    ELK - They're not meant to "level" the T@B just to stabilize it once it's level by other means (blocks or whatever) - to keep it from wiggling as you move around inside.
  • ChanW
    ChanW Member Posts: 3,165
    I've used the stabilizers as the manual says, 'drop the tongue all the way to the ground, lower the rear stabilizers, then crank the tongue jack up, to lift the wheels'... Haven't had a problem with it.
    Some folks have suggested that this might be an error in the manual, but I guess I'm waiting for LG to "print a retraction", if that's the case.
  • Nomad
    ChanW - Thinking that once the stabilizer is all the way down (kind of locked in max position) might be different than say trying to crank the T@B up as in leveling it - Ya think?
  • ChanW
    edited September 2015
    Yeah, I agree PXL. Any time I try to crank too hard on the stabilizers, it's clear they aren't made for lifting.
    I think they'd fail mechanically, the screw thread would strip or lock up, if they were pushed too hard.
    I would like to have LG's opinion on this bit of instructions in the manual (can you get their attention on it, Mike or Verna?)
  • Verna
    Verna Member Posts: 6,876
    LG stands by their instructions of temporarily using the stabilizers to assist in changing a tire. I don't have the instructions in front of me, but you guys have read it. I talked to Scott Hubble at length about tire changing at Tearstock. We did not discuss using the stabilizers for anything other than stabilizing for daily use and for tire changing.
    For me, I will use an 8 ton bottle jack if I need to change a tire.  It's my personal solution, and what I am comfortable with. You guys can use the stabilizers as described by LG or use a jack. Be very careful either way.
  • ChanW
    Thanks Verna.
  • DurangoTaB
    Verna...after going through the recent learning process that the lug nuts are different on the spare than the regular tires, I thought about using my bottle jack from my Tacoma on the T@B.  Anyone have suggestions here to place it?  Axle?  Frame?
    J.D. & Sue
  • ChanW
    A reminder about putting a jack under the Tab is that Alko, the axle manufacturer, says to never put the jack under the eccentric tube axle. Put it under the frame or a brace, or use a large block of wood to spread the weight on the axle.
    Lifting there could easily dent the tube, which would damage the spring part of the suspension system.
  • Photomom
    Photomom Member Posts: 2,217
    If you did use the stabilizers while changing a tire, wouldn't you just lower them on the side of the trailer that has the flat tire? In that case much of the trailer weight would be supported by the good tire which is still on the ground.
  • Verna
    Read what Chan just wrote after your comment. Use the frame for your jack. I would place the jack either directly in front of or directly behind the affected tire under the frame.
  • ChanW
    The manual says to lift both tires at the same time if using the stabilizers.
    Note, you aren't really lifting with the stabilizers, you're lifting with the tongue jack. That is. You don't crank on the stabilizers to lift the weight, you crank on the tongue jack.
    I'd follow the book on that, rather than straining the stabilizer on only one side.
  • wizard1880
    wizard1880 Member Posts: 442
    That makes sense. So the stabilizers can handle the weight of the entire back, but they just can't be cranked to lift that weight up--the tongue jack will. ;)
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • Nomad
    wizard - That's pretty much it - Just make sure the stabilizers are cranked all the way down - not sure they'd hold the weight otherwise.
  • vito
    I just tried it and it worked without a problem. I had the stabilizers down, cranked the jack up enough to slide the dolly wheel on, then cranked the stabilizers up just a bit. Then I moved the T@b a few feet (I have just had my driveway and surrounding area redone with all new asphalt and was advised not to leave the T@b in one spot for too long during the first month while the asphalt fully cures). Then I lowered the stabilizers all the way down (onto 8x8x2 blocks of wood), then raised the dolly wheel up and slid under the wheel another block of wood. I know the T@b is not heavy, but I still find it infinitely easier to move around with the dolly wheel than with having to lift and carry the jack. I guess I will go through this little exercise weekly until I reach at least a month with the new asphalt unless I take it on the road sooner.
    2016 T@b S Maxx
    2011 Subaru Outback
    Rockford, Illinois
  • USWildflowers
    USWildflowers Member Posts: 177
    When some axle work was being done at the factory on my T@b, they had the weight on the tongue and the rear stabilizers while BOTH wheels were off the trailer.
  • Verna
    Thankfully they weren't on the shoulder of an interstate with the 18 wheelers whizzing by.
  • dougsarm
    dougsarm Member Posts: 5
    Haven't ordered our TAB yet, but in this discussion of changing tires, how hard is it to find a tire repair or replacement shop when your on the road?
    Dougsarm
  • Verna
    Dougsarm
    AAA+RV was there in about 45 minutes.
  • Nomad
    Luckily I haven't had to use them but I've got the AAA+RV also. Wouldn't leave home without it :-)
  • Dalehelman
    According to Bal. Stabilizing jacks are rated 700 lbs lifting and 1000 lbs load per Jack. The answer to the OP would be yes.
    1. Hash  T@B Fun
  • vito
    I've now left the T@b on the stabilizers twice (of course the bulk of the weight is still on the inflated wheels) while raising the jack to put the dolly wheel on and off and its worked fine. No sagging or sounds of strain on the stabilizers. I bought a bottle jack as a just in case thing so that if I ever needed to change a wheel I have a way to support the T@b. But I only would be doing this if I was unable to call AAA.
    2016 T@b S Maxx
    2011 Subaru Outback
    Rockford, Illinois
  • Wross
    Wross Member Posts: 19
    Dougsarm
    Ddougsarm;
    if you call AAA or a similar service you will find fairly universal tow service almost everywhere on interstate highways. If you go to Goodyear.com or Michelin you will finf a dealer locator for tire stores.
    there is natiowide coverage. I own Walker Tire and Automotive, we are in Austin TX
    we dispatch our truck 24x7 in our coverage area with a 2 hour "roll time" in our area of coverage.
    you will find similar coverage across the country. We do charge more for night or weekend calls.
    walter
  • Sgtjohn
    They will-even if part way down.  I do it every time I take the T@B out of the garage, jack it up enough to put a block under the frame near the wheels, let the front jack down and extend the stabilizers again and get the hubs high enough to put the wheels on and I'm ready for the road!
  • Nomad
    It works till it doesn't :-)
  • Apopejoy
    Apopejoy Member Posts: 14
    After reading these comments and manual instructions I take it no one recommends a girl undertake to change a TAB tire on the side of the road?  It sounds like it would be difficult even for a guy.
    Max S. Tumb@lweed, north Texas.
  • Nomad
    Apopejoy - I think either male or female "could" do it. But if you're a traveler, one should probably have a roadside assit plan like AAA+RV so it's easier to not mess with it.
