Carpet over floor with stock heater
Thanks in advance for any imput.
2022 T@B 320 CSS BD
22016 4Runner
Coeur d' Alene ID
Well you will be putting an insulating layer on the floor, which, in my opinion, will interfere with heating and defeat the purpose of the heated floor. It will eventually get warm but it will take a while. Common sense tells me it's not a good idea.2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0
Damn! Wish my 320 had a heated floor.
... edit that carpet may block the intake of the convection heat.Stockton, New Jersey
@TravelBug; Many folks, myself included, just use small rugs . . . house kitchen sink area or bathroom size rugs. These provide middle of the night bare foot comfort, can add color, are very easy to clean (just shake them outside) and most of all do not block the Alde incoming air vents located at the bottom edge of all the benches. Those air gaps must be clear for the Alde cabin heat to function.
webers3 said:Well you will be putting an insulating layer on the floor, which, in my opinion, will interfere with heating and defeat the purpose of the heated floor. It will eventually get warm but it will take a while. Common sense tells me it's not a good idea.
I worked in an industry which included radiant floor heat. It’s done quite often.
The following is from a search up.
"Can You Put Carpet Over Radiant Floor Heating?
Yes, you can install carpet over radiant floor heating. Doing so enhances comfort while maintaining the efficiency of your heating system. It’s essential to consider specific guidelines and potential challenges during installation.
Installation Guidelines
Choose the Right Carpet: Select carpets made from materials with low thermal resistance, such as wool or nylon. Short pile carpets maximize heat transfer, promoting effective heating.
Use Appropriate Padding: Opt for carpet padding designed for heated floors. This type of padding allows heat to pass through efficiently while providing cushioning."
2021 T@B 400 BD
2021 Ford F150 2.7 turbo0 -
westernstates said:Doing so enhances comfort while maintaining the efficiency of your heating system.
Sorry but this is counterintuitive
webers3 said:Well you will be putting an insulating layer on the floor, which, in my opinion, will interfere with heating and defeat the purpose of the heated floor. It will eventually get warm but it will take a while. Common sense tells me it's not a good idea.I worked in an industry which included radiant floor heat. It’s done quite often.
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0 -
webers3 said:I was being sarcastic in my previous post hoping that some one would comment. Does the 2024 320 T@B have radiant heat in the floor? I've never heard of that.
Regardless, this is the carpet we use in our 2020 320S. Works well as long as you don't block the intake for the convection heat.
@webers3, @westernstates
The TAB 320, 360, and 400 do not have "heated floors".
The 400 does have heat under the wetbath shower pan . . . but not a heated floor as such.
Like This:
Adventures: 61 Nights: 417 Towing Miles 51,0503 -
@MuttonChops I do not have 2024 320 so I assume that @TravelBug knows better than I what type of heating 2024 320 has when asking about heated floor. Anyway, covering heated floor with a carpet doesn't make sense.
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut1
