Shoe storage mod
Kevin_K
Kevin_K Member Posts: 38
We are starting our 5th year with our 2021 Tab 400 and one of the things my wife hates is our method of storing our shoes. In the past, they simply were swept under the dining room table, or placed on the shelf just below the table (which would always come off after a move). We do a lot of activities (hiking, biking, kayaking, and simply lounging around the fire), so it requires a lot of different shoes. Some get placed in the tow vehicle, but not enough. So my wife came up with an idea to install a netting under the table to place the shoes in. I went one step further. This shoe rack is made of of netting and 1" and 2" nylon straps. It has space for four sets of shoes. The shelf behind the netting can also be used to store your hiking boots or larger sized footwear. I suppose you could use this idea for other things. If there is enough interest, I could probably try to come up with a drawing. I got most of the material from seattlefabrics.com.
2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk
  • FriendsofMario
    FriendsofMario Member Posts: 47
    edited May 3
    Neat idea!  As of now, we’re using a tension rod under the table.  It fits three pairs of sneakers there but from time to time we have to make sure it’s tight.
    2019 T@B 400 BDL
    2025 Ford F-150
  • Droid
    Droid Member Posts: 14
    I hear you, so many shoes! Here is what I’m doing. I cut a hole in the small part of the bench next to the door on my 2018 400, so I can slip some shoes in and out. That wasn’t enough so when I modified the compartment under the bed I created another hole for shoes. Not everyone may want to cut holes, but it is how I created the shoe storage.
