Can I charge my Tab320 Battleborn with my Hybrid 4Runner?
Rick24
Member Posts: 17
I have a 2024 Tab320 with a Battleborn battery. Can I charge it from my 4Runner? Can I just pull an extension cord from my 4Runner inverter to my 320? I tried connecting my Hughes Watchdog to the 4Runner inverter but it said there was an open ground. Do I even need to use the Watchdog?
Should work, depending on the inverter output you might be limited to just battery charging with no other 120V appliances running. The ground issue is common with all sorts of portable power stations and such because they obviously do not have a proper ground connection. Just connect the trailer without the watchdog.1
I charge my lithium in my Tab 400 with my F-150 Powerboost (hybrid) with the 7.2KW inverter and even use it as a power source for the AC if necessary.
If your tToyota inverter has the capacity you should be fine.2021 Tab 400 Boondock
2020 Audi SQ51
