Inclosed under body
Dalehelman
Member Posts: 2,414
To be better prepared for winter here in the NW. I decided to insulate and inclose my fresh water and gray water holding tanks. The side rails lend themselves fairly well to the challenge. I used 1/2" foil backed rigid foam from HD. I lined the side rails and the bottom. Then I inclosed the the area between the rails and from the spare tire to the tongue with black corrogated plastic. I bought the plastic from a local RV repair shop. All in all it went quite well and I would do it again. Sorry pictures were very hard to show how it was done. Foam cost about $12. The plastic is very durable and used for this purpose but cost about $100. Plus some self taping screws and fender washers.
- Hash T@B Fun
Pics please...
Pictures
- Hash T@B Fun
Why are you insulating the tanks? Without a heat source of either vented air from a furnace, such as in motorhomes, or heated tank pads. There will not be a heat absorbed through the floor of the T@B, as it is basically insulated. I see wires, so I assume you might have heating pads?
150 watts 30 feet 120 volt wire heat. It can be used on shore power or my 400 watt inverter.jdargis said:Why are you insulating the tanks? Without a heat source of either vented air from a furnace, such as in motorhomes, or heated tank pads. There will not be a heat absorbed through the floor of the T@B, as it is basically insulated. I see wires, so I assume you might have heating pads?- Hash T@B Fun
How long can you go on the inverter with what size battery?
I am installing a remote thermometer between the tanks to monitor temps so heat can be applied as needed. When in motion the TV can maintain the inverter. I carry 2 12 volt batteries plus a 2000 watt generator. I will also install a computer fan in the floor vent under the frig to take advantage of the heat generated by the frig. It vents into the under belly.
- Hash T@B Fun
Sounds like you're rseariously eady for cold weather - Personally, after spending 60+years in MN winters - my goal is to avoid extremes in weather and/or temps :-)
We go south for a month or two in the winter. I just like to be ready for the unexpected coming and going. Mostly I just like tinkering with our T@B. I am always looking for the next project.
- Hash T@B Fun
Can I stop by, you can tinker with mine all yo want :-)
- 916 Introductions
- 72 Teardrop Groups & Links
