Outlet in Outside Storage
scott14
scott14 Member Posts: 198
We have a 2019 TAB 400. It occurred to me, after owning the 400 for several seasons, that I don't know what the component is that is plugged into the outlet in the outside storage compartment? It seems like a silly question that I should know the answer to. Anyone help?
Thank you!
    qhumberd Administrator, Moderator Posts: 878
    edited May 24
    @scott14 On my model I found this plug right next to the passenger storage door when I was swapping my original batteries.
    For us the outlet had a plug attached for the 2 way frig when on shore power. There is a single outlet here that is a plug for the 12 V fridge. I used a splitter so I could keep it plugged in and also use the small Lithium charger for a top off when on shore power.
    IMG_1932.JPG IMG_1933.JPG Plug Passenger cargo bay 2.JPG Plug passenger cargo bay door.JPG
  • scott14
    @qhumberd The plug location is exactly as you note. I wondered about the fridge but thought since it was a 12 volt it didn't have any AC power running to it. Your explanation above makes sense.
    Thank you!
    MuttonChops Member Posts: 2,057
    @scott14 early TAB 400 model years used both the 120V and 12VDC Fridge connections.
    Sometime around 2020-2022 nuCamp switched to only connecting the 12VDC even if the Fridge itself was 120V compatible . . .
  • scott14
    @MuttonChops Thank you for the information.
