Amount of room under the bed for 2025 Tab 400
Good morning and Happy Memorial Weekend= Honor our fallen this day
That said I need all of your help. I need to know the amount of room under the bed from the base to the top of the plywood where the Batteries are mounted. I wish to place a New self heating battery . This battery is 9.95 inches tall and is self heating. Also given excellent reviews on its construction and 460 amp hours of service. At 105 lbs its less then the 4 BB batteries currently under the bed. The good news is the terminals are approximately 1 in lower then the top of the battery so I could put the battery in the compartment even if the top was 10 inches.
Please help.
Sincerely Todd P
    qhumberd Administrator, Moderator Posts: 915
    @SavvyNurseCamper on my 2019 400 the false floor that was holding the batteries near the foot of the bed is right at 10 3/4 inches to the bottom of the bed platform. My replacement lithium is
    L19*W6.7*H9.5 inch
    and it fits with with plenty of clearance. You should be fine but will have a bit more than 1/2 inch at the top.
  • SavvyNurseCamper
    @qhumberd Perfect! Thank you! VATRER POWER 12.8V 460Ah Self-Heating LiFePO4 RV Battery, APP Monitoring, Built-in 300A BMS, Max. 3840W Load Power, 5880Wh Usable Energy. This is what I will replace the BB batteries with. Saving myself an additional 19 lbs and self heating. 😉
