Dometic cooktop push igniter
I have removed the push button mechanism after the AAA battery leaked. There are two components to the igniter. Does anyone know if the push button part can be found without getting both components? I’ve looked/can’t find. Dometic told me they don’t carry those parts anymore!
    Year of TAB and Stovetop Type (model?) would be helpful to know.
    There does not appear to be many Dometic 'AA / AAA battery igniter' references on the web. There are several gas grill 'AA' battery igniters . . . full assembly $10 - $30 depending on source and model.
    You might have to adapt a gas grill unit or just live with using an external flame (match, etc) to light burners.
  • Simba75
    Simba75 Member Posts: 3
    edited May 31
    Thanks for responding. The Dometic 2 burner gas cooktop (model d21) is in a 2021 Tab 400 Boondock. The gas burners do still ignite manually (with match or lighter or spark maker). Looks like I will just get the “kit” containing both components.
    Repairing to sell.
    @Sinbo75: "cooktop (model d21) is in a 2021 Tab 400"
    Interesting, thanks. I had no idea nuCamp was using the 'extra AAA' battery model. Seems like a poor selection with all the 12VDC capacity available.
    But then, nuCamp continues to install the cheapest stovetop on the market . . . strange considering their higher build quality, unique designs, and Adle usage.
  • Simba75
    it worked great (and we do like the cooktop) until the AAA bat leaked.
