Check Your Breakaway Brake Switches
ScottG
ScottG Administrator Posts: 5,662
As part of your pre-season maintenance routine, I suggest checking the operation of your breakaway brake switch. This is easy to do, but also easy to overlook.
With the battery connected, pull the pin from the switch box. There should be a notable voltage drop, and the wheels should lock up.
When I tested mine this year, I got nada. Sometimes I could get it to engage by banging on the switch housing with a wrench. I'm guessing the internal contacts are corroded.
Replacement switches are easy to come by for as low as $10. The biggest challenge to installation would be splicing in the new switch wires.
