2013 T@B Little Guy-damaged grey water tank?
When I returned from camping this weekend I noticed something hanging from the base of my T@b camper. It appears to be connected to my grey water tank.
  • Grumpy_G
    Grumpy_G Member Posts: 758
    Affirmative. There are (or should be) two metal brackets that hook around the edge of the tank right where the rust stains are.
    pthomas745 Administrator, Moderator Posts: 4,623
    Where is this thing exactly? The tank itself is pretty hard plastic. Under the shower area there is a cover for the shower trap that is a metal rectangle, but the shape and position of what is "dangling" appears wrong.
    Have you crawled under there to see what you can see?
    MuttonChops Member Posts: 2,022
    Yep, as @Grumpy_G noted the metal brackets have failed.
    That is the Gray Water Tank . . . not something connected to it 😉
    Your 2013 should be about the same as this picture :
