Water pump switch on Control Panel broke
Hello all— Help please—2018 Tab 400-- the little toggle on off switch for the water pump just broke - cannot pump any water -- the switch just flip flops up & down. Can the entire KIB panel be replaced? Or just this switch? Is it even possible to get a new panel or switches for this trailer? Thank you
2018 Tab 400
    pthomas745 Administrator, Moderator Posts: 4,699
    I'm not sure what exactly your KIB monitor looks like.A quick search online showed all sorts of different arrangements.
    But, it should be easy to unscrew from the wall and take a look. There are KIB monitor switches out there, and probably some generic ones that will work.
    KIB Pump Switch Amazon
    There are other examples there on the Amazon page. If it is as simple as removing the old switch and reattaching the connectors, it should work.
    MuttonChops Member Posts: 2,078
    Don't a 2018 400 still have the SeeLevel ? 320's did.
    Replacing pump switch on the SeeLevel is doable.
    qhumberd Administrator, Moderator Posts: 912
    Found this thread indicating that the switch can be found at an auto parts store…
    Thread about 2018 T@B 400 water pump switch
  • lkc001
    lkc001 Member Posts: 881
    i actually don’t know— I will have to see if I even have any paperwork on this — am not the original owner & missing some of the paperwork— thanks for the heads up
    2018 Tab 400
    @lkc001 This is what the KIB monitor looks like (different years have different looks).
    See Level panel looks like this. There is a ton of wiring info for the See Level panel, but I bet either pump switch will be easy to install.
    The old Travels with Delaney YouTube videos showed most all the systems on his T@B 400, which was a 2018 model. Looks like the KIB monitor panel that @pthomas745 shows.
    Since you have a 2018 you might look up the playlist on this channel as it has a lot of 5 min short videos on the 2018 T@B 400
    Travels with Delaney Water Tank Video
