new 360CS ... trying to find all the drain valves and spigots?
Hi,
We just bought a new 2026 TAB 360CS. So far, so good. We haven't drained any tanks yet, except for gray water emptying. Now I want to drain the fresh water tanks and sanitize them. I can't seem to locate all the drain points and valves. Especially the fresh water and the Alde water.
Are their any photos out there?
2026 TAB 360 CS with Boondock upgrade
Tow vehicle: Ford Ranger 2021
<deleted> <was not accurate>
Look on the Driver Side between Cassette Tank Door and Tire, on the trailer frame.
Those Three Drain Points [near white labels] most likely include the Fresh Water Tank.
That is the best picture I could find, it is from a nüCamp 360 CSS Marketing Video.
Would be great if you would provide a better quality picture from your rig.
Thanks. I will take a look for it and post a pic when I can. The camper is at a local storage place
since we can't keep it at home.
@albireo13 ; For the Alde Boiler Tank Drain
Look in the Alde Compartment (lift board cover).
There should be one or two Yellow Handle Pressure Relief Valves.
They have a secondary function of draining the tank and/or tank area water loops.- Alde 3030 will have one
- Alde 3030 Plus will generally have two
when you open those undercarriage drain valves, be sure to smile as they give you a face full of water. There is a solution for that in some 3d printed 90 degree elbows that direct the flow of water at the ground and not at your face :)
2023 TAB 400, towed by 2001 Ford f-150 Supercrew XLT 5.6 liter v80
