I am thinking of using a little heater for my TAB 400 BD camper. It draws 6.5amps or 750 watts. D
VV99
Member Posts: 2
I am thinking of using a little 120VAC heater for my TAB 400 BD camper. It draws 6.5amps or 750 watts. Do you think it will trip my breakers?
Best Answer
The short answer is there should not be a problem plugging in a 750 watt heater 6.5 amp, when you are on shore power. If you propose doing this from battery power using an inverter, the calculation changes.
But since the T@B 400 has both the Alde or the Coolcat that can provide heat, the question is what you are trying to achieve with the small heater.
2
Answers
