Mystery Switch - Resolved
Any ideas on what this rocker switch controls? It is a lighted rocker switch located to the left of the Jensen radio above the refrigerator. I have not been able to figure out what it does.🤷
2020 Tab 400 Lite
2025 Hyundai Palisade
Tubac, AZ and Alpine, AZ
Some folks install those to control power to the Jenson to eliminate the power draw when it's off. Does it control power to the Jenson or anything else nearby?
Rich2019 T@b 400
That is most likely the Factory Installed 3-Way Fridge 12VDC Operation enable/disable Switch.
Some 3-Ways auto-select power source, switch allows owner to stop all 12VDC operation as the 3-Way Fridge has a huge DC current demand, keep it off use Fridge as ice chest save battery power.
Note: Most tow vehicle +12VDC 7-pin circuits don't provide enough current to fully run the Fridge, the extra demand is pulled from the battery.
Reference:
Yes, @MuttonChops is correct. If you want to run the fridge on 12v, you need to turn on that switch (green light should come on if I recall).
2021 400 Boondock / Jax, FL
2018 320-S0 -
@Rich that was the first thing I tried. It doesn't power the Jensen.
@MuttonChops and psuvtech You may have solved two problems for me. I was going to take it to the dealer to see why I can't run the fridge on 12v. I will try the switch and running on 12v and see if you solved the mystery.
Thank you,
Roy
2020 Tab 400 Lite
I just tried turning on the switch and now I can run the fridge on 12v. You guys are good.
Thanks
2020 Tab 400 Lite
