Best Way to Remove Exterior Caulk
manyman297
manyman297 Member Posts: 1,436
My 2021 400 needs some resealing done on a couple of the portal windows. It sounds like Geocel 2300 is the sealant of choice. What's the best method of removal of the old sealant?
2021 400 BD
2020 Tacoma TRD Off-Road
  • Slackers
    Slackers Member Posts: 490
    To remove caulk around the exterior shower box I used a plastic putty knife to carefully pry off the old. I then cleaned it up with denatured alcohol. I used a Geocel product but don't recall which.
  • manyman297
    Awesome. Thanks!
    2021 400 BD
  • Horigan
    Horigan Member Posts: 916
    Even a better cleaner is 3M Adhesive Remover.
    Rich
    2019 T@b 400
    Bellingham WA
  • Slackers
    I used Geocel 2810 Pro Flex RV Flexible Sealant around the shower box.  I purchased it from Amazon.
  • Gkopan
    Gkopan Member Posts: 47
    For removal of remnants of old exterior caulk on exterior siding left after scraping most off, would mineral spirits be fine?
    2021 T@B 400 Boondock; TV: 2019 F150 3.5 EB
  • Gkopan
  • manyman297
    @Gkopan A lot depends on the type of adhesive but I've used mineral spirits with good success on Geocel products. I always start with rubbing alcohol and work my way up to more extreme measures.
    2021 400 BD
  • Gkopan
    Thank you
  • Horigan
    WD-40 is also a surprisingly good adhesive remover.  Also consider 3M Adhesive Remover, which I find to be very effective and safe on all surfaces I've tried.
    Rich
    2019 T@b 400
    Bellingham WA
  • manyman297
    @Horigan Yes! WD-40...I always forget about using it but lately I've had good success using it on a lot of adhesive residue.
    2021 400 BD
  • Basil48192
    Basil48192 Member Posts: 441
    @manyman297.  Just a hint: Have all surface prepared, clean and ready before you open the tube.  I found that the Geocel products set up quickly....even in the tube once it has been opened.  Towards the end of my caulking it was getting harder and harder to smooth out the bead with my finger.
  • manyman297
    @Basil48192 I’m going to try Quad OSI this time around. Geocel didn’t last and Sikaflex 221 didn’t stick to the acrylic windows. I found Geocel difficult to get a clean bead. Using automotive masking tape (the green stuff) I was able to get a crazy good bead laid down but it just didn’t want to adhere fully to the porthole windows.
    2021 400 BD
  • Basil48192
    A quick comment about removing old, exterior caulk.
    I found that Goo Gone Spray Gel Adhesive Remover really works well to remove the old caulk.  I rub it into the joint with an old cloth to prevent dripping.  After a few minutes the old caulk softens quite a bit.  Then I use the plastic 'chisels' shown below to scrape the gooey mess off.  The plastic doesn't scratch the finish and it can be easily sharpened with a fine grit sandpaper. Lastly, I clean the joint well with rubbing alcohol before applying new caulk.  I hope this helps!
  • LouiseC
    LouiseC Member Posts: 4
    Does old caulk always need to be removed?
    If the old caulk is in a nice bead and not significantly cracked or delaminated, just old, would it be OK to clean off the caulk and nearby surfaces with rubbing alcohol and then apply new sealant over the old, making sure to lap beyond the edges of the old?
    2019 T@B 320S, purchased used in 2026
