Hepvo Valve Broken?
Hi! I'm new! I just purchased a 2022 Tab 400 Boondock from a dealer in Colorado who said he drained the lines, but he did not add any antifreeze. However, when I got it home to Gunnison, CO, the grey water tank STUNK SO BAD! I put antifreeze in and waited a coupe of days, but the smell was still horrible. So then I dumped the grey water (and the black water to be safe), flushed the antifreeze and put vinegar in all my drains and let it slosh around. It sat for about 2 days and the smell is much better. Then I drained that and added Camco TST Pro for grey tanks, and it's sitting in there now before I leave for AZ. Seems better, and maybe it's just a residual stuck up in my nose haha. But what are the chances my Hepvo drains are broken or maybe stuck open?
They do get stuck slightly open sometimes. I've heard the cause is lack of flow. If enough water flows through the valve is should stay clean.
I've not had problems with mine; however, ours was in use every month.
2018 320CS-S
"Just Enough"0 -
Welcome to the forum, nooch!
We also have a 2022 T@B 400 Boondock and live in western CO. Did you get an 2022 Owner's Manual and a Nautilus P3 User Instructions when you purchased the trailer? If not, message me with your email address and I will send both of them to you in PDF. (I also have many other product manuals if you should need them.)
The Owner's Manual includes the blowout/antifreeze winterization process (regarding your other post) and the P3 Manual explains how to sanitize your fresh water tank. Every spring I sanitize our fresh water tank and then pump all that sanitizing solution (diluted bleach water) through each fixture (kitchen sink, bathroom sink, shower, and toilet) and into the grey tank (and pour a couple of buckets of the sanitizing solution into the toilet). I let that solution sit in the tanks a couple of days and then drain the tanks. We've never had an issue with stinky tanks. You may want to put a little sanitizing solution into your grey and black tanks to let the solution slosh around as you drive to AZ. (For the record, I also pump some of the solution through our outdoor shower valve.) I hope this helps.
2022 T@B 400 BD, 2018 Toyota Tundra, Palisade, CO0
