Tire Blowout with Damage to T@b320
grassgd
grassgd Member Posts: 161
Last week after about 80 miles of towing at 60 to 70 mph had a passenger side blowout which caused damage to the trailer floor behind the wheel well. Thankful it was on the passenger side otherwise would have had damage to the plumbing under the drivers side under seat equipment. Blowout was an immediate failure and was able to pull over immediately without damage to the aluminum rim. Next problem was a conventional scissor jack could not lift the trailer since it has to be completely collapsed (lowest height) to fit under jacking point. This was a scissor from a 1 ton pick-up truck. Had to call AAA roadside assistance to use a low profile floor jack to change the tire. (Did not want to use the unhook the trailer for the TV, lower the trailer tongue and extend the rear stabilizer to raise the trailer since I could get road side assistance). Drove to nearest Discount Tire and got 2 new tires. See pictures of damage below:
Currently working on repair which will include substantial protection on both sides to protect form trailer flooring from future tire blowout - especially the drivers side.
Anyone else have this type of problem caused by a tire failure?
Will post pictures of repair and protection for future problems as I go.
2019 T@B 320S
  • GBL_citruscountyfl
    GBL_citruscountyfl Member Posts: 35
    Because this is structural, I would contact your insurance. They may total it since the floor is essentially a structural panel that is bonded together and can't just be patched. If you decided to do your own fix, and you ever have an accident, they may not cover your RV if it comes back to this issue. I've had the insurance total one of my rvs for a tiny dent in the frame, which I thought could be welded.
    2018 Honda Ridgeline FWD
    2020 400 solo
