Replacing "Board" on Alde 3010 - Solved
2»
  • RollinWithShirley
    RollinWithShirley Member Posts: 60
    you said to reach into the alde compartment and touch the circulation pump. Is my photo showing the circulation pump? The sound I have been hearing seems more like a fan than a pump.
  • RollinWithShirley
    @MuttonChops. I have gone through the whole sequence. Thank you for the crystal clear instructions. The pump did not come on at either power level . The propane switch is turned off. When I attached the jumper from 2 to 6, the propane light went on for an instant and then I heard the sound from the Alde, but I think it is the fan rather than the pump.
  • RollinWithShirley
    @MuttonChops @JanandDave. I just had a nice conversation with Dave and he is sending me a control panel by mail.
    Yes, that is the Circulation Pump.
    Propane Indicator light and combustion fan turning on is an interesting 'failure mode'.
    Glad you have located a replacement Control Panel.
  • RollinWithShirley
    @JanandDave @MuttonChops @pthomas745
    YAHOO! I plugged in the control panel that Dave sent me and the heater pump turned right on. It works on shore power and propane. Thank you everyone on this thread for helping me out. It took six months in all, but I seem to be good to go. You are a valued brain trust.
    Wow, this has been quite a story. @RollinWithShirley good for you for sticking to the process. There is a lot of good information in the thread about the manual panel that is sort of new, and you helped with that.
    But: @JanandDave are the heroes here!
