USB-A to USB-C Conversion
Has anybody replaced the two USB-A ports below the 400 dinette with USB-C outlets. The USB-A sockets don't appear to pop out from above, but maybe I'm not prying hard enough?
You could just use these:
2023 T@B 400 Boondock2026 Haven 220
Thanks. That is an option. I was hoping to take advantage of the faster charging rates with USB-C, which those adapters wouldn't provide.
Rich2019 T@b 400
@Horigan I had those USB outlets get cracked when we accidentally lowered the table while something was plugged in. The outlets for me were only accessible by popping off that grey cover and then removing the screws for the whole outlet. I recall its a plastic screw ring that holds those in place. Since they are in a kind of awkward spot, we just tapped those supply wires and added another outlet on the seat panel closer to the bath and that has a USB - C that works fine.
Thanks @qhumberd, That's exactly what I was looking for in understanding how it was assembled.
Thanks @gkreitzburg. Thinking on this more, we don't really need the higher USB-C charging there as we typically charge overnight, or while using a laptop at the table. I'm gonna go with your adapter route for now. Thank you!
Rich2019 T@b 400
I recently installed a combination usb-c and usb-a plug elsewhere in my 400. With some disassembly, it could be done where the present under-table outlet is, or off to the side as qhumberd did. I went with Coolgear products: a small circuit board and socket. The company is US based, reliable, responsive and produces rugged products:Dual Port, Panel Mount. The DC adaptor board is ESD protected, thermal, and over-voltage protected: a good choice for an RV or trailer.
