UPP (Ultimate Protection Plan) offered by Nucamp
I purchased a 2026 Nucamp Tab 360 last March. I have until next March to decide whether the UPP is worthwhile. It gives one some peace of mind, but is it worth the cost? I expect I'll have significantly less repair costs than $5,000 in 7 years. But would appreciate some advice.
In general I avoid extended protection plans as Insurance Companies are very good at denying claims based on fine-print. A big plus for this UPP is nüCamp not an insurance person judges the claim.
Have you read the 10-page Terms & Conditions?
What is covered is impressive; Alde, A/C, Fridge, Microwave, etc.
Which could be a positive if you need to sell the rig in the next seven years.What is Excluded needs to be considered (just a few I noticed):
- . . . Camper is intended to be used on a recreational basis. Use of the Camper as a long-
term residence (in excess of 60 nights per year) will void this Extended Warrant . . . I'm averaging 48 nights a year usage and would like to increase it. So for myself a 60 night rule is an issue. - . . . Failure to properly maintain or service the Camper, . . . Locate & Read the required owner maintenance and ask if DIY is allowed or must a Dealer completed.
- . . . Failure to use reasonable efforts to mitigate damage caused by defect . . . Starting to get into the lawyer talk and claim gray area.
As you noted, most likely you will never use $5K worth of repair/replacement. The Alde Boiler is one, if not only, really big ticket item.
Adventures: 61 Nights: 417 Towing Miles 51,0503 - . . . Camper is intended to be used on a recreational basis. Use of the Camper as a long-
@MuttonChopsmakes some excellent points. More to consider: are you near a dealer and are they any good? The fridge is about $2000 (easy to replace). The alde is about $3000 (more challenging). It's 7 years from purchase date, so only six additional years coverage. The likelihood of both big ticket items failing is quite low… but if course you could be the outlier!
Put the $5000 in a money market account and after 6 years, if you didn't use any of if for repairs, you'll have a nice chunk of about $6000 for the Next Camper Fund. And, if by some string of bad luck, you have paid for over $5000 worth of repairs in that six years, you're not out that amount…you just broke even to the warranty cost.
Of course I feel like if you follow this advice your camper will fall apart…so don't blame me ok 😆
3
