Wheel source for 2006 T@B
roadapple
Member Posts: 2
My “new to me” 2006 T@B has 16 X 7JJ 5-spoke Alloy Wheels. While going over the trailer today I pulled the spare tire from under the trailer to check it.
I found it to be a 13” steel wheel and tire. This spare will definitely not do.
Can any member inform me of a source for new or used early T@B OEM alloy wheels or tell me of any other automotive wheels that will fit my T@B?
Thanks in advance.
The T@Bwagen: 2006 "L" Model
TV: 2012 Toyota FJ Cruiser
Cerritos, CA
No matter where you go...There you are.
Cerritos, CA
Have you tried calling Little Guy World Wide?The HobbiT@B, 2015-L, towed by a2014 RAM C/V
The bolt pattern is 5-112 mm. There are many online wheel stores to search on that.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
You may also need to know the offset (difference in alignment of the wheel rims with where the lug nuts are attached). You can have a tire shop measure your existing.
Just purchased a 15X6 5X112mm +41mm steel rim and a 215 /60 R15 tire for the spare. Diameter is within 1/4" of the existing tires with more inside and outboard clearance. Now all I have to do is machine down a set of lug bolts to provide clearance to the brake components inside of the hub due to the thinner wheel material.
Thanks for the help!The T@Bwagen: 2006 "L" Model
Cerritos, CA
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
