Generator for AC
Dave28
Member Posts: 40
Hello,
I am a new TAB owner. I have a Yamaha EF2000iS generator (1600 running watts/16 amps). Would that be enough to run the TAB A/C? Thank you in advance for your advice.
I would think so. We have a "16 T@B Max S and will try our Honda 2000i soon and report backJohn - Kris & our Golden "Blossom"
South Carolina
Live simply,Love generously,Care deeply,Speak Kindly,Leave the rest to God0 -
Yep, it should. Like John&Kris, I have the Honda 2000i.
The general take is you need that 2000w for startup but once running not near that. When I start the air it doesn't even throw the Honda into high gear. I wouldn't be surprised if you could run the AC with a 1000 watt'r but they say you can burn out the compressor if too low.0 -
As a comparison - A toaster throws it into high gear instantaneously.0
boo - If I wasn't out boondocking (photography) so much, was just a normal camper, I'd probably not have invested in a generator and just head for campgrounds with hookups if I needed air. A 2000 watt'r isn't the lightest thing in the world, takes up space and you have to carry gas. To run the air around the clock you'd need 3-4 gallons of gas per day. My main use is to keep my computer charged while photo editing and for rainy days when solar won't work.0
The friedrich AC unit needs 1500+ to start, and only consumes 400-600w during usage. A toaster generally takes 850w+ for just a 2 slot, so you can imagine that would stress the generator more, at least for a couple minutes.
My only caution would be that it may not work at high altitudes. My 2000w Champion generator would not run an ac at 6600 feet (Signal Mountain Campground in Grand Teton NP).Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA0
J.D. & Sue
