I could ask Renogy this question but don't know if they're familiar with our T@Bs so I'm coming to the experts! If I were to get two Renogy solar suitcase products (I was told I could connect 2 together) would I get a controller that says positive ground or one that says negative ground? I know Jenn said Renogy now sells the correct plug to go right into our Zamp port but have heard about the wires are "reversed" (which is way over my head). If I order two I know I need to order a separate controller and those two choices are listed (positive vs. negative ground). Anyone?
0 ·
With the above being said, Zamp's solar port is designed for their solar panels. This means that IF you are holding the charge wire hooked to the back of one of their solar panels, the exposed or bare connection on the panel wiring harness end is in fact the ground side of the solar panel. They wire their panels this way (with safety in mind) because if the panel is outside or is in a position to where it is exposed to and is gathering sunlight there is a current flow through the wiring harness. Should someone accidentally make contact with a grounded surface this will protect the panel from any damage, as will the fuse in the solar panel.
The "reversed" scenario or concern only comes into play when you are trying to use the Zamp port when hooking up a battery tender. If you plug-in a battery tender (without flipping the Zamp leads (which is not really a good idea) to the Zamp solar port without modifying the battery tender quick disconnect the tender will not charge or maintain the battery because the battery tender wire leads are reversed. So you would need to cut the battery tender wire lead, flip the wiring and splice them back together (+positive connected to negative and - negative connected to positive). The bottom line here is that the Zamp solar ports are built specifically for their solar panels and were never intended by Zamp Solar to be used to hook up a battery tender. This is what creates the confusion therein.
Hopefully this helps to clear things up for you and helps to answers your question above. And if it were me, I would call Renogy and ask to speak to their solar tech, Jesse. He is a very helpful man, very knowledgeable and will tell you the correct charge controller to buy and the most efficient means of doing so. Feel free to tell him I recommended you call him as he is a great guy and is very giving of his time when answering questions and helping people out.
Good luck!
I could call and ask for Jesse as you suggest (if he works for Renogy). I do not want to purchase anything until I'm positive of what I need to get to make this work!
My mistake on Jesse as yes, he does work for Zamp.
The Renogy panels will have the MC4 leads on the back of the panels. You can purchase varying length MC4 wires on Amazon and that is where I picked up my Renogy panel and the wires with connectors. I'd be curious as to how you plan to use your panels and what kind of panels you are considering? Are you going to hinge them together and buy mounting legs to create a portable set-up? Nonetheless you might want to call Renogy or look for additional information on-line via YouTube or Google if you have further questions in pairing the two panels and getting them configured properly. It sounds like you have done some homework already and when you get things finalized I'd enjoy seeing some photos of your set-up in use.
