12v battery volt meter with USB charger
Just installed a simple low cost 12 volt meter with dual USB charging ports. I laid out and marked where I wanted to mount it, drilled two 1-1/4" holes mounted the plate with the USB and volt meter, I tapped into the 12 power supply on the led light circuit for power, start to finish about 20 minutes. Works great and simple to install. I order it from Amazon for $16.99 here's some pic's.
