Installing Cup Holders in a T@b
Tabbieannecamper
Member Posts: 33
We have a 2015 MaxxS. One of the things my wife and I enjoy doing is having a couple cups of coffee especially when it is raining. I purchased two stailess steel cup holders. I don't want to damage anything behind the walls. My selected location is in the space between the rear of the side window and the cabinet door in the rear. Has anyone installed cup holders in their T@b? If so, what type of screws did you use?
If you search, there have been a couple threads about cup holders. I can't remember the specifics but the walls don't take screws well as they are just the 1/4 inch wallboard. I've used 3M command strips for some fairly heavy loads, you might try them.
The wall is made up of a sandwich of very thin wood with a foam core between. It is light and has good insulation qualities, but cannot take any kind of load.
you best bet is a very good two sided tape or to find a good location somewhere on the wood to place the cup holders. I know folks have installed them, so it can be done.
Sterling, VA -
See what we did here...
http://tab-rv.vanillaforums.com/discussion/1182/cup-holders# -
We used the flip down cup holders and used double stick tape and small full thread screws and hey seam to be doing wellJohn - Kris & our Golden "Blossom"
South Carolina
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
