Lagun table support
With some time gone by, how satisfied are you with the Lagun table support?  Does it collapse easily, store away quickly and are you satisfied with the stability of the table when assembled.  Other than the cost, any pros or cons you can mention about it?  Weather dumped here in WI, so I haven't had the chance to install ours, yet.
  • Tabaz
    Tabaz Member Posts: 2,421
    Two thumbs-up, Five Stars, Academy Award for Best T@B Table.  Love the fact I don't have to remove it while traveling and how it easily swivels out of the way during the day.  Could not be happier with it.
  • JustJohn
    JustJohn Member Posts: 171
    I agree with Outback, no negatives so far and more open area. One positive is you can decide the size of the table based on your needs. Can be quickly removed for travel and out of the way when not needed. What more could it do?
  • Verna
    Verna Member Posts: 6,876
    It's great!  I want to cut about 3" off in width on mine, but that's my fault.  I'll make my permanent table when I get home and by then I'll know exactly what size to make the table top.  The temporary plywood one is doing just fine.
  • John_and_Kris
    John_and_Kris Member Posts: 302
    We just cut our top and its now in the finishing stages. We made one of the dimensions so that we can use it on the bed slats supports we made. Right now it is 29 1/4 ' by 16 " we will see how that works
    South Carolina
  • Michigan_Mike
    It's like night & day from the old table that I now use as a grooming table for my dog.  Much more convenient and people can actually sit around the table without tripping over the table legs of the old unit.  The table swivels easily, allows for multiple uses and can be easily removed when the need arises.
  • cbarnhill
    cbarnhill Member Posts: 330
    I like mine, too. I took the cushion out on the drivers side bench and installed it there. Underneath I have my mini micro and a makeshift pull out drawer. I love it there just as a stationary table. But it can be pulled out and used by just about every section of the cabin.
    Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)
