outback front platform
Don't have one so can't give dimensions but there's been a couple threads recently about mounting tubs, generators and such. Try a search on "outback" or "outback platform" and you'll probably find what you need.0
Here is how I have mine configured. The Tupperware box and water jug holders are bolted to the platform. You need to be careful when ordering any type of box because of the curved handles on each side of the T@B - they tend to get in the way of the lid. Another option is to install a storage box in front of curved battery/propane box and behind the jack handle. Two people at T@Bazona had them, and they looked pretty cool. Probably also a lot cheaper than the platform.
2024 Ford F150 Supercrew short bed.1 -
My solution not 100% finished just yet. Im able to store dual 6v battery's. Honda 2000 and Viking propane tank inside. More pics when project is complete. And yes thanks to other members of forum.
I have expanded metal under frame tongue area and front diamond plate hinges up with sewer hose storage. Tony D
Central,Fl
2015 T@B Max-S1 -
I can't wait to photos of the inside.Tonydjd said:My solution not 100% finished just yet. Im able to store dual 6v battery's. Honda 2000 and Viking propane tank inside. More pics when project is complete. And yes thanks to other members of forum.
OMG! That looks so cool! Great design.2016 Outback 320
If you want another way to mount the 8-gallon action packer bin to the platform these look to be a good solution. http://http//www.swagoffroad.com/8-Gallon-Rubber-Maid-Action-Packer-Baja-Bins_p_35.html
OutbackAZ: can you post the measurments for each sideeof the platform? Just the depth amd the width along the back from the end to the existing diamond playe box. Thanks
You could fit a rectangular box 20" wide by 14" deep on each side. The bottom of the box would extend to the outer edge of the tubular frame. Hope this helps.
We put a storage box in front of the propane storage box fits great and holds our odd and ends ( power cord, hoses and the like). Will use one side for our Honda 2000i and the other for gas and chocks.John - Kris & our Golden "Blossom"
South Carolina
Live simply,Love generously,Care deeply,Speak Kindly,Leave the rest to God0 -
The box we put on the front was from Cabelas, Called a Poly Storage Box Small
# IK-52-3780 hold quite a bit waterproof and locableJohn - Kris & our Golden "Blossom"
South Carolina
