 Tonydjd
                    Member Posts: 111
Tonydjd
                    Member Posts: 111
 Well here goes couple pics. Removed lead acid installed AGM inside unit. Installed  shut off switch on box outside. Removed steel tank installed viking. Note I had to move propane regulator to do this install.
Central,Fl
2015 T@B Max-S
Central,Fl
2015 T@B Max-S
Really like bike storage solution!
Thanks.
Central,Fl
2015 T@B Max-S
I always liked Michigan Mike's way of drilling a few holes and putting water hose screens in the holes, and then using a marine metal "shell" on the outside to keep water out. If he didn't post the pictures on the T@B forum, he definitely posted it on the Little Guy forum.
Battery inside unit with 4amp charger. Note I also have battery switch installed on unit. So when being stored in shop. I only have charger plugged in not on board inverter.
Battery inside AGM
Central,Fl
2015 T@B Max-S
Central,Fl
2015 T@B Max-S
