Fuse blows when I plug in shore power.
With shore power plugged in, everything works fine with no battery fuse.
If I replace the battery fuse after unplugging shore power, everything runs off the battery fine until I plug in again, then 'poof', fuse is gone.
Is this very obviously something in particular? We're taking a week long boon dock soon and would love to (need to?) have battery power.
                0 ·
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
To deduce the problem, one thing I did was recharge the battery. Didn't help.
I took the cover off the electric box under the trailer and it was full of water.
I'm guessing the converter must be sending too much power to the battery when it wants to charge. That's my layman conclusion.
I'll have to arrange for service after camping season is done.
What was throwing me off previously was my multi-meter was indicating a full charge because I wasn't aware you had to wait for surface charge to dissipate... As well, the various appliances appeared to run fine off the nearly discharged battery.
Regardless, trickle charged the battery at 2A for about a day and a half, all is well and I'm a little wiser from the experience!
This is Deputydog. Did I help???? This is GREAT. I try but usualay fail. This is a first.
 A first.
  A first.
Otherwise, give it a few hours.
You'll actually see on the multimeter the slow discharge. If you can hold a constant measurement to two decimal places for 10+ seconds, I'd say you're discharged.
This is of course coming from a guy who just found out surface charge is a thing.
