RZRBUG
Member Posts: 890
The cover for my stove sits down in a recessed area, just loose. A couple of times it has bounced out while traveling down the road. I have since started taping it down.
Has anyone come up with a solution for this problem? It would be nice to have some type of hinge, which I understand the newer models have.
Happy Trails Y'all
Problem solved -- I hope.
I didn't try the magnets because the lip is so narrow I didn't think they would work. I did try industrial strength Velcro and ran into basically the same problem. There was not enough area to stick enough to hold it down. I even tried mounting putty. Not.
So, today I ordered the hinged cover. I actually liked the glass cover better, but could not figure a way to keep it from bouncing out.
Oh, and I even checked around for no drill glass door hinges, but could not find any that I thought would work because of the lip of the stove.
Happy Trails Y'all
Happy Trails Y'all
Well, back to the drawing board. The cover came today, and although it says it will fit ALL Suburban drop in two burner stoves, it does not fit mine. The back of the cover has square corners; my stove has round corners. In addition, the cover is wider in depth than my stove. So, if you have the Suburban SDN2 model, these hinged covers you see advertised on the Internet will not fit.
Headed out Thursday, but when I get back I will scratch my head until I figure out a way to put a hinged cover on that stove...or until the rest of my hair is gone.
Happy Trails Y'all
Happy Trails Y'all
Just to tie up a loose end, my final solution was to order the stock hinged cover. It was not quite as simple as take out the old, insert new. The hinged cover has to have notches cut into the countertop to accommodated the hinges, which swing down and back. Or, you could just cut a wider opening. I only discovered this after I had already removed the stove and attached the cover. So, it was take the cover back off, remove the stove again, and cut notches in the countertop. The new cover has a wider lip at the back to cover up the notches (and hide my not-so-perfect woodworking skills). Anyway, glad it's done. It's so much better than just having a loose glass cover sitting on the stove.
Happy Trails Y'all
