Width of the "Front Cushions" on T@B
I have a Dutchman Clamshell which have the split side cushions. I know the Little Guy new clamshells have a solid cushion all the way across.
We always leave the bed made up in either a single bed or double bed depending on if I'm solo or with hubby. We remove the cushions and put 8" of foam in for the bed.
When I'm solo, I leave the front cushions in and put 8" of foam across the back.
My question is what is the width of the front cushions for those that have models where the cushions are split from the sofa in the back?
I would love to get the front cushions from the Sofitel to replace my current front cushions. But if they are too big, not an option really.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
  • MouseketabMouseketab Member Posts: 1,238
    Also, would Pleasant Valley even sell me just the front cushions from a Sofitel?
    Carol
    MOUSE-KE-T@B
    Harvest, AL
    Mouseketab-are these the front cushions you were referring to? Base cushion measures 20 1/2 wide by 32 inches long. Wall cushion measures 14 1/2 inches high by 32 inches long. This is a 2017 max s sofitel.
    Yes! that's what I'm referring to. I'm hoping that equals to the front half of my clam cushions :)
    Carol
    MOUSE-KE-T@B
    Harvest, AL
    Well shoot, mine are like 28 1/2"
    Carol
    MOUSE-KE-T@B
    Harvest, AL
    Sorry to hear they're not a perfect fit to begin with. Do you have a clamshell or inside kitchen? Don't give up hope. Maybe PV can custom make/assemble. Easy enough to cut the foam down from 32 inches to fit your size. Much more difficult to make it longer. Same goes for precut fabric. Easy to cut down to meet your needs. Hard to make it larger. Can't hurt to ask. Plz let me know what you find out. Curious myself now that I think about how the factory might help you.
    I have a clamshell. Yes the factory could probably do something custom, but then so could I. Was just hoping to pick up a set pre-made, easy peasy while I was at Tearstock next week. I will ask Elsie if they have any 28.5 cushions, but if not, I'll just pick up some foam and sew cushion covers myself.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
