XL visor
AlanAlan Member Posts: 120
can th XL visor be laundered in a regular washing machine?
    I'm thinking the answer is probably not.  PahaQue advises that for their tents,  "...use a non-abrasive sponge, cold water, and a non-detergent soap to clean the inside and outside. Any cleaning products with a perfume smell will attract bugs. Once it is fully dry, pack away in a room temperature, dry location."  Jason told me at Tearstock to definitely NOT use any petroleum-based cleaning products.
    Happy Trails Y'all
    States Visited Map
    Washing tents of any kind is never a good idea. Most have coatings, seam tapes, etc, that will be damaged.
    edited August 2016
    I used Palmolive on mine to clean it, used a soft bristle brush and hosed it off with the jet setting on the spray attachment to my hose.  It dried quickly and I folded and stored it.
    Agree with Photomom too, washing the T@B tents isn't recommended by Paha Que as it can remove the waterproof coating and they warn against doing this.
    Paha Que FAQ
