Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
An ALDE question that may be simple
Restless_Native
Member Posts: 117
Some of you know I picked up a brand new T@B at Tearstock because the one I got in May was missing some of the customizations I had ordered. Well I a just using the hot water for the first time and no joy. I unscrewed the benches that house the ALDE and this is what I found. Is it supposed to be plugged in or do they wire it in? There is a plug on the inside of the bench with nothing plugged into it.
Amanda, Ft. Myers, FL Ag@tha 2017 T@B CS-S , TV: 2013 Chevy Equinoz LTZ
As I recall, mine's plugged in there - That hidden 110 outlet.
I'd take a pic but inaccessable at the moment -
Yep - definitely has to be plugged into that outlet. I would make sure you're not connected to shore power or the battery when you plug it in. Mine blew an Alde fuse (under the cover) when I plugged mine in.2016 Outback 320
Ok great! I'll unplug it and give it a try! Thanks!!Amanda, Ft. Myers, FL Ag@tha 2017 T@B CS-S , TV: 2013 Chevy Equinoz LTZ
That worked! Thanks so much. I know these are finicky and I didn't want to fry something. Simple plug in and good to go! I love this thing!Amanda, Ft. Myers, FL Ag@tha 2017 T@B CS-S , TV: 2013 Chevy Equinoz LTZ
Works better when you plug it in! :-)John and Henrietta, Late 2016 T@B S Max in Western New York
And there is no reason to unplug it between trips.Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.
- 916 Introductions
- 72 Teardrop Groups & Links
