T@B Sofitel, 2016 - No water from fresh water tank.
Sierranevada
Sierranevada Member Posts: 5
Fresh water worked fine on our last trip 4 weeks ago, but this weekend, water only worked when attached to hookup. No fresh water from tank.
Any ideas? Power on, pump on, tank full.. no water comes out.
  • Nomad
    Nomad Member Posts: 7,209
    Could have an air buble in the pump line - has happened to others.
    Might search "no water" or "water pump" or something similar - theres remedies outlined.
  • Sierranevada
    Thanks PXLated. Air could be it since I did empty my tank after last trip.
  • Sierranevada
    How does one remove an air bubble, in the fresh water line?
  • Nomad
    One method is detaching the fresh water hose from the pump and sucking :-)
    There's others if you search. I've had luck with it just working itself out with the sloshing while traveling.
  • Sierranevada
    FIXED: I put my fresh water hose down about 5 inches into fresh water hole on side. Blew with all my might. About 10 or 15 blows in, I heard the water under my sink  run. I opened the drain valves and water came out. I closed them and turned on my water pump - BAM! Problem  solved. Must have been an air bubble. I had drained my fresh water tank after the last trip. I won't be doing that again.
  • Nomad
    Glad you got it working.
    I had a bubble once that prevented me from filling the tank more than half way - The sloshing during travel worked it out and was able to finish filling at my next stop.
