 Smullis7
                    Member Posts: 221
Smullis7
                    Member Posts: 221
            During my recent camping trip, the digital Alde 310 thermostat popped up a Fan Failure error. I searched the manual and found a small paragraph that basically said the error meant the fan had failed and to disconnect the 12v power from the furnace...also that it would reset in 5 minutes...which is almost exactly how long it took me to dig out the manual and find the error information. It reset and all has been fine. My question is has anyone seen this before and what would cause it. I want to make sure I don't do whatever that was again.
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
The glycol tank is under the back shelf - you need to remove 2-3 screws to get at it. On mine it's under the shelf on the drivers side.
If you have a 2017 look for your expansion tank here. Loosen any screws and slide the panel towards the front of the trailer.
Thanks for the info on the glycol tank...I'd never have guessed it was under the shelf.
"Fan Failure" is a very specific error message, displayed on the Standby Screen. It indicates the combustion fan has not reached sufficient speed (rpm) or possibly isn't moving at all. In a brand new installation, this is most likely stiffness. After a few attempts it should loosen off (indeed in the latest control panels the error message "Fan Restarts..." is displayed).
In an older installation, it could be the fan motor is failing, or a poor connection; the fan is connected to the boiler PCB by a short cable.
