Searched and after 4-pages of returns, found a thread from 2014 - Know Verna got new ones last year...
Need new tires on the TV and my T@Bs aren't down to the wear nubs yet but figured since I had the flat and have to visit a tire shop would start fresh. What are the latest recommendations...
0 ·
Happy Trails Y'all
Happy Trails Y'all
What did you two pay if I might add?
Happy Trails Y'all
And the Discount Tire I went to said the Airstream travel trailers are like our T@B's in that you can't put a jack under the axle.
Haven't looked at the spare that came with the T@B, could get a match and use the good tire as a spare till I get back to a big town and familiar territory. Mental noodling :-)
Honestly, I don't think it matters what you get, as long as you replace them after 6 years or the tread wears out.
2014 T@B CS Maxx
Martha Lake, WA
Here's a little technical dive into the matter, and how I look at it. The tires are somewhat over rated, by design, for the T@B when it is at maximum cargo limit (GVWR). For example, if you have a model with the 3500 lbs axle, your tires are probably rated near 2000 lbs each. Our campers come anywhere from 1400-1800 lbs empty, roughly, depending on model.
Let's say you've got your water and waste tanks full, plus a full compliment of gear, and your camper now weighs 2600. That's 1100-1500 on each tire, depending on how it's loaded side to side. Tongue weight also reduces tire load, but let's just leave this out for simplicity sakes.
Your tires, then, are only using 75% of their rating. It varies from tire to tire, but you can reduce the tire pressure to accommodate the load. This way, they're not bouncing down the road and showing over inflation wear. This is why many of us choose to lower our pressure proportionally to weight. I do this, but add 5-10% as a buffer, by personal choice
Most T@Bs out there have the 2700 lbs axle I believe, so if you're fully loaded check your tire max load and do the math, to see where you should keep your pressure safely. I keep mine at 42 lbs (max 50).
It's also a good idea to check your tires often during your trip. At each fuel up or rest stop, etc, put your hands on the tire treads. If the outdoor temperature is winter or spring-like (60s), your tire tread should feel lukewarm to cold. If the weather is warmer or even hot (80+), the tires will be warm, but they should never be hot enough to burn your hand, or smell like hot rubber (unless your tires are less than a year old).
It's also a good idea to test your bearings temp by feeling the lug nuts. They should be the same as the outdoor temp, or warm if you braked down a large hill or did a lot of city driving just before testing. If they're hot, or especially if one side is hotter than the other, get your axles inspected and greased ASAP.
This is what I've learned from personal experience and Internet forums research over the years. My gospel ain't everyone's gospel, but I hope to help anyone who's curious.
2014 T@B CS Maxx
Martha Lake, WA
Our 2017 T@B tires have a speed rating of 75 molded into the sidewall. I wouldn't trust them at that speed.
Alan & Patty
Southern Az
On the tire brand and model issue, I have heard people say you must get trailer-rated tires. I think this is bunk. If you buy a tire with the right load rating, any road or AT tire should be fine.
What do you think?
(previous 2018, T@B 320 Outback)
Alan & Patty
Southern Az
